reverse lights?
reverse lights?
my reverse lights have gone out and i can't find the problem....
all the fuses in the box are good and the bulbs are fine. what else could control the reverse lights?
Car: 1989 Iroc Z
Engine: 5.7 TPI
Has anybody ever painted there backup lights blue or red or anything. I'm thinking about painting my backup lights Blue.
Check the sockets themselves. Alot of times the copper contacts will get corroded and won't make contact with the bulb. If they are corroded, scrape it off with a pick or screwdriver and then put dielectric grease in there.
Other than that, check the parking safety switch on the shifter. You said that the relay is clicking, but verify that the input on it is recieving power, and that the output is putting out power. It's possible that the coil is activating like it should within the relay, but it's input or output is dead.
If it's not either of those, start tracing wires
Good luck
And your car is beautiful BTW. I love those new rims
Good luck
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
http://members.cardomain.com/tamatt27
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Kevin
i don't know if i would call it stupid because if it were a show car they should do whatever they like. however i feel it would definately look stupid and on the street your taking a chance of causing an accident which if they found out you changed the color of the lights you would be held liable wether it was your fault or not. not the brightest idea for a street driven car.
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Have you checked the switch on the B&M? My rev lights used to go on in drive and not go on in reverse and do weird things but i bent the little metal arm a tad and did some adjusting w/ the shifter and it worked fine. It might be the switch is dead too
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey Kandied...(kind of off the subject) but you said you have the mega shifter right? Did you use the shift plate that it came with? I'd like to get one for my 91...but I'm not a huge fan of how the shift plate looks that it comes with....just thought I'd ask. Thanks Dude
Hotrodboba400
12-10-2019 07:07 PM
