backs of rear seats??? >:O
Car: 1986 Pontiac Trans Am
Engine: LG4 305
how in the heck do you get the backs of the rear seats out... i see there is a rod going into it from the middle of the car, and there is a pivoting area on the other side. do you use a torx bit the get the screw out for the pivoting point or what? what size?
1 Post
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
yes it's a torx bit,don't know the size, theres no room for a driver though, i put the torx bit in an adgustible wrench and did it that way. not fun though let me tell you. what a PITA. thats why i have not put it back in for six months.
Car: 85 Trans Am WS6
Engine: 305HO L69
if memory serves me correctly, it's a hex bolt, either 10mm, 13mm, 1/2" or 9/16". sorry if i'm not narrowing it down much, but i know it's a hex head, not a torx head. the striker bolts that the back seat latches onto when it's in the up position is a torx head though.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
the seat on my z 28 have a 10 mm hex nut on each hinge on the bottom of the seat. you have to remove the seat bottoms to se them. don;'t know if the bird is diffrent.
Car: 85 Camaro SC
Engine: V6
On my solid bench rear seat there are 2 bolts on the fold down part of the seat. On the bottom outer edges of the seat there is a 10-14 mm hex head bolt holding the seat down. Just need an extension to get into the corner. Its the same for the split bench seat.
Then for the bucket seat part there is 1 10-14 mm hex head bolt in the front center part of the seat. The way to find it is by feeling under the seat for the bolt.
If you have rear belts than remove the belt-guide from each backrest.
Remove the lower seat cushins using a 13mm socket & Extension .
Remove the 13mm nuts from the bottom outside corner of each seat backrest.
Pull each of the backrest away from the mounting pins in the center of the car.
Then,......................
<REVERSE PROCEDURE>
<REVERSE PROCEDURE>
1992 Trans Am
05-10-2023 07:19 PM
