Seatbelt Replacement?
Car: 1988 IROC-Z
Engine: 355ci TPI WORKED TO THE BALLS!
Transmission: 700R4 T-56 coming
My driverside needs to be replaced is there an easy way to do it? the top goes into the headliner. I dont want to destroy it the car has t-tops and the liner is in decent shape thnkjs.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
After you pull the headliner it's easy. You'll see what I mean when you get to that point.
Car: '91 Firebird
Speaking of, I'm replacing my front seatbelts with black ones. The latches next to the console... how do I get these out without breaking/scratching up anything? Mainly I'm talking about the plastic cap at the bottom of it.
