Update on my wheel well rust
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Well i posted about 6 months-a year ago that my baby was getting cancer alround its wheel wells...
With many of your condolences and some hard work i can say the cancer has went into remission!!!
sorry it took so long but i did the rust proofing about 5 months ago, but with no digital camera i have to make the best of thing swhen i have one...
before....
after.....
before....
after.....
incase ya didnt catch it... First pic = rust...
Second Pic = no rust
I sanded it all down with a palm sander... i then realized the palm sander was **** and i decided to use an angle grinder with a Flap Disc.....
Flap Disc's are the ****!
Next, after i sanded all the pivits out and featherd out the sanding to match the lines of the wheel well, i applied heavy coats of Naval Jelly (its a rust proofing Product) on the area and then i rinsed it off...
Next i applied 3 coats of Rustoleum Primer (Grey) and i let that sit and cure for a day.
The next day i sanded the primer and applied 5 coats of Duplicolor Canyon Red and let that set for 3 hours and then i applied 2 cans of Duplicolor Clear Acrylic.
I let that sit for a day and then i sanded the area with 1500g wet sand. Then i washed the area and Applied some rubbing compound and an orbital Polisher.
that is the afterproduct..
which by the way is about 4 months old and i am seeing no pitting or signs of rust.
In case your unaware....
Rattle cans are just the exact same principle of a pnumatic sprayer....
Compressed air pushing the paint through the nossle. If you know how to do it you can make it look excellent.
just be patient, slow, steady and even.... i plan on painting my entire car, by myself, with rattle cans....
I helped a friend when he was prepping his van for a respray and he did the whole thing with just cans. It was a pretty cheap van and hence not worth spending real cash on it but I was very impressed with how well he go it to turn out.
i rattle canned my rear bumper after sanding it down to bare fiberglass...turned out really really well, you can't tell it's been touched other that the paint is a slight different color....black car go figure, since black is one of the hardest colors to match up due to sun fade.
Youll have to wait till i get a digital camera to get better updated pics..
There is absolutly no sign of it coming back.
Yes, i am dead serious about doing it with spray cans... and if you know how to use them its just as good as using a sprayer from a compressor......
ambainb
04-25-2016 09:21 PM
