convertible painting
I will give my car some new paint. I have a few questions:
- any problems to remove gfx, tonneau cover, spoiler ?
- can the rubber seal aroound the windshield be removed and replaced without taknig out the glass?
- are the body moldings on the door glued on or are there holes (i think about removing them)
thx
thx
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Re: convertible painting
thx
thx
- yes, the vert bracing makes the GFX very hard to get off... if you do a search on it, you'll find a rather nice how to.
the clear plastic around the black part on the tonneau cover needs to come up before paint, and should be replaced afterward... but its expencive. price it first. 3M makes the clear sheet you need
the two sides of course dont come off... the actual spoiler on the trunk supposidly unbolts, but i never tried it.
- the rubber seal around the windshield can be removed carefully... but you will probly distroy it while doing it... you'll have to get a new one afterward.... btw be sure you find replacement vert top weather stripping along the windshield edge before you tear the old one off
i have no idea on the doors.
Car: '87 Z
Engine: 355 in the works
Not to get off subject or anything... but what's wrong with your paint? The pics you've posted lately look AWESOME. Looked to me like she still had shine left in her...
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
The door molding is just glued on, if you mean the horizontal 'stripe' of molding in three pieces. You should have no problem removing that.
Car: '89 GTA
Engine: ZZ6TPI
The side molding are held on with double-sided tape. A nice trick to get them off is to use piano wire or thin mechanic's wire. Start at one end work it back and forth cutting the tape until you get to the other end. It works like a cheese slicer. This way, the molding doesn't deform like it would if you just pulled it off.
1 Post
Car: Z28
The older style molding is rivited to the door with a cover over the rivets. You first remove the cover with a screwdriver by prying it then drill out the rivets.
Car: 91 Camaro Vert
Originally posted by 89rsragtop
Don't try to remove the caps on the rear fenders that's where ASC cut the top off to make it a convertible. They don't come off.
1 Post
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I have no idea how they were attached to the car. But the body shop that redid my car, and removed everything else said it was a bad idea to try to remove them. They also did not remove the black vinyl part from the tonnaeu cover. This is just my $.02. You can take it for what it is or is not worth.
P.S. They did remove,But complained loudly about the GFX. By the time they were done they were not big fans of ASC. LOL
Car: 91 Camaro Vert
Originally posted by TPl383
BS. on the side caps not coming off. They used double sided sticky tape on my 91vert.
mine def arnt held on with sticky tape its some kind of bonding gunk.
