Bolts For My Front Seats Are Rusted And Wont MOVE AT ALL
Car: Trans Am
Transmission: Automatic
Somebody Gave Me A 91 Camaro RS Which I Was Gonna Take The Seats Out Of To Put In My 86 Trans Am I Went To Go Take The Front Seats Out Of The Trans Am And The Bolts On My Trans Am Are Very Badly Rusted So Much That They Dont Move At All What Should I Do To Get Thease Bolts Out
Mike
1986 Trans Am 305 TPI
1991 Camaro 305 TBI TOTALED BY DRUNK DRIVER
Mike
If you need the seat tracks then you need to find a way to lose those nuts, heat is always a winner in those cases, just be careful cause yer pretty close to many things that are VERY flammable.
If you just want the seat from the Camaro, well cut the tracks and take the seats out. Just re-use the tracks of your Birdy.
Hope this helps.
Hope this helps.
Car: 91RS
Engine: 305tbi
I'm guessing since it was given to him and he is pulling the seats its probably a junk car anyway. If its a junk car, there are always bolt cutters
Car: Trans Am
no the junk car the bolts came out easy but in my car the old seats are the ones thats rusted
Mike
Mike
Car: 85 Camaro SC
Engine: V6
Your best bet is to soak them with Pb blaster or liquid wrech. That will penatrate the threads and lube everyting. Also go nice and easy, loosen the nut slightly and then go back to tighten it some, then loosen it up some more. Doing that will help with removal. What ever you do dont get a bigger wrench unless you want to break a stud off. More torque isnt always the answer.
Car: 91RS
Engine: 305tbi
Oh right
As already said, do the liquid wrench thing, soaking it for a day or even longer should make it alot easier. Just remember, no job is done right if it doesn't involve bolt cutters, a crowbar, an axe, or my favorite the sledgehammer
Car: 1986 IROC-Z
Axle/Gears: Dont know yet
I had the same problem with my 86 IROC a few months ago. I just used some liquid wrench, let it sit for a few hours and the bolts came undone easily. Mine were rusted pretty good too. Had to get old seats out to put in 99 T/A seats.
1992 Trans Am
05-10-2023 07:19 PM
AkDrifted
08-17-2015 07:45 PM
