Help !!!!!!! Question on Door
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 87 Irocz, 95 Z28, 71 Z28 /RS
Engine: 355 Tpi, LT1, 355
Transmission: Auto, Auto, 4sp
Ok my husband & I have been just getting started on working on our 82 indy pace car. Today my husband ran in to a couple problems.
When we bought the car We knew the drivers door sagged because the old owner didnt correctly replaced the pins. So Today my huband desided he was going to take off the GFX & Try to get the door hung right. Well when he took off the door he found this. (pic attached)
My question is what years car door? I do know alot about these cars BUT I am just making sure that I can get a newer door with out a problem.
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
82-92 doesn't matter. From a Firebird or Camaro.
I am putting Firebird doors on my car right now, I just hafta weld in the old holes for the ground effects...since they are located higher than needed for my Camaro ones.
1 Post
Ok thanks thats what my husband thought, But I wanted to make sure. Looks like I go out Junk yard hopping this weekend & get me a set of 91-92 Z doors.
Also Anyone know where I can find the complete set of GFX for the 82???? Cant really find them on line.
1 Post
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
try Phoenix Graphix @ http://www.phoenixgraphix.com/
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Be sure to get doors complete with the triangle parts and all the window mechanisms intact, as the 82 system is different than the 83-92.
Pete
Pete
1 Post
Thanks pete if I change out the whole door I am going to use the guts from the Door I have sitting in my garage. I was told yesterday since its an org Pacecar door I might just want to reskin it.
Thirdybird its ok I have made mistakes in the past.
