Removable Steering wheel
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
OK I have seen a Grant steering wheel setup that is an anti-theft device that allows you to remove your steering wheel and lock a cover on the colum when you park your car.
Has any one out ther used this setup, and is is easy to defeat and steel the car anyway?
1 Post
Car: '82 Z28
Engine: 350HO
Transmission: M4
someone here is using it, but i forget who.
it works great, if you don't mind carrying your steering wheel around.
how many car theifs carry a spare steering wheel around with the correct linkage to attach to the grant device?
The Grant device uses a key to lock the potecting plate on also, I was tempted to get it myself.
I have 2nd hand testimony that, like all removable steering wheels, they get loose and have a bit a bit of play over time. That is why they get replaced quite often. This has steered me away from removeable steering wheels and am looking into a good alarm system with my own little tricks to stop theives.
backtothe80s
09-05-2015 12:39 AM
