keeping floor boards shining
hey guys i have come up with this idea to fabricate my floor boards out of diamond plate (1/16th)
basically my question is
will aluminum rust?
i dont want to take on this huge project and then have it rust on me
will aluminum rust?
Car: 1990 Formula
Engine: 305 TBI (LO3)
Transmission: 5 speed manual
well it won't rust...i believe rust only occurs in iron but there could be some other oxidation you need to worry about...someone who remembers chemistry better could tell you
Car: 1991 Chevy Camaro RS
Engine: 283
Transmission: 700r4 Auto
lmao @ your quote matts90firebird!
sounds like a good idea but i dont know about the rust
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
just keep it nice and dry, clean, and you should be fine
1 Post
Car: 85 Camaro
Aluminum does rust, it'll grow a white scale (look at aluminum rims). About the best way to keep it in check is by anodizing it and that can get expensive.
Car: 1985 firebird
Engine: 2.8 173 v6
Transmission: The one it came with
I remember seeing a site that showed you how to do it at home, the guy used a bucket some kind of acid, a battery, and i forget what else , looked kind of easy the way he showed it. I forget the site though, try doing a search on the net.
1 Post
Car: 85 Camaro
you could anodize small parts at home but i wouldnt try to anodize/alodine something the size of a floor pan at home, not sure if you would want to weld material with anodizing/alodine on it either.
Aluminum does NOT rust. It oxidizes, which is a step below rust. You can paint Aluminum the same way you would paint any car part, you don't necessarily have to anodize it.
The problem I see with this idea is quite simple, there is almost no way to weld aluminum to steel and make it hold, especially for the kind of weight your floor pan will have to hold (no offense to you intended). You would have to make your entire car out of aluminum, or rivet the floor pan in place.
Mathius
Mathius
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
The little i have in my car gets scratched sooo easy (fine ones mind you)...and cause its all bumpy, its kind of hard to polish. I bet if its on the floor it would get scuffed easy cause of little dirt on shoes. Not my cup of tea...but its some flashy i tell yah.
take a look, not a good pic but it gives you alittle idea...
