underdash trim
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 88 Camaro SC
Engine: 2.8 ->305->350
underdash trim
2 quick questions ... How many pieces of under dash trim came in 88 RS's and 2 how many curtosy lights should I have.. I count 4 ..... Under the hood , back in the hatch ..... and 1 on either side under the dash. Were there any others?
hehe, there's a thread about this going on over in the history forum right now.
I think most of us had two panels. Also called "hush panels".Scott Moyer doesn't have any on his Iroc, and although no one has been able to conclude who did, and who didn't have panels, It seems that obviously not everyone has both, or even any for that matter. If your car did NOT have either panel, both lower courtesy lights should have metal mounting brackets. As for me, both of my courtesy lights mount into my hush panels.
As for lights, my 89 Iroc has 2 underdash by my feet, 1 in the hatch, and 1 overhead. I also have 2 maplights in the mirror, and the undervent/HVAC light which never seems to have ever worked for anyone....but it's there none the less.
...and of course under the hood.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
I rigged up that undervent light to work i had to pop the bulb out of the little casing and do a little searching t find a tiny bulb and just wired it up and now that i have it i don't like it it's too bright at night i think i'm gonna replace the bulb i put in it with a dim led bulb and see how that goes
Car: 91 Camaro RS
Engine: 3.1L V-6
and i don't think i have an courtesy lights in the footwells or at least they don't work and i've never found them to replace the bulbs
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Not really Camaro related, but my 86 Trans Am had one in each hush panel. My 88 Formula is the same.
If you count all the lights on the inside,
I have the hatch light, dome light, 2 hush panel lights, one light above the headlight switch, and one light above the vent controls which can be seen in this video, http://www.transamws6.com/video/gauges.mpg
1Aauto
Sponsored Vendors
11-09-2015 02:25 PM
