Window weather striping or whatever you call that
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
Ok, the rubber linning on the top of the door is cracked where do i get new ones and how do i install it?
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
i think you may mean the felt strip that goes on top of the door on the outside of the window. like this one. may not be the best image.
if it is this one you have to remove the door panel one the inside of the car. and then loosen the window felt tabs 2 of them to alow the window to tilt in toward the interior so you can get at the screws. i think there are about 8 screws that hold it in place. pretty easy to change. check out hawks sponosred link on this page they have them.
1 Post
Engine: 305 tpi LB9
the black pastic triangle that the window rides in? that does not come with the wiper strip.
SPEEDY Z28
09-15-2015 05:34 PM
blackandblue02
09-10-2015 08:19 PM
