Will 4th gen sun visers work in a 3rd gen?
Old 10-16-2003 | 03:53 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Will 4th gen sunvisers work in a 91 T/A without T-tops.
Mine are sagging and worn out. I have access to a pair of 99 Camaro sunvisers but wasnt sure if they would work.
Any idea if they will?
Old 10-16-2003 | 04:06 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Hey, I aked the same question as you. They should work. Here is a link to the other thread.
https://www.thirdgen.org/techbb2/sho...+gen+sunvisors
Old 10-16-2003 | 04:09 PM
BLURR's Avatar
Car: 1989 Iroc Z
Engine: 5.7 TPI
Cool, well then while Im at the wrecking yard this afternoon picking up my 4th gen console Ill get the sunvisors out of the 99 Camaro also.
thanks man
Old 10-16-2003 | 07:31 PM
onebinky's Avatar
If the holes don't line up exactly, you could always just redrill the holes. I couldn't find any decent sunvisors for my 81 camaro, so I found some out of a thunderbird. The centershaft was the same diameter, so I just redrilled the outer 3 screw holes. They worked perfect until some lady in a topaz felt the need to pull out in front of me and wreck my car...
Matt
Old 10-17-2003 | 03:20 AM
thechristopherh's Avatar
yes they will fit but you will need to redrill holes or they will sit at a really odd angle. im doing it with mine, i had mine mounted in, but i had the holes lined up wrong with the roof holes so the visor would swing back and hit the passenger in the face. psh i dunno
1992rs/ss
05-19-2020 08:02 PM
1992rs/ss
16
01-28-2016 10:58 PM
Eagle223usa
Brakes
08-14-2015 10:24 AM
dhonda200
08-12-2015 12:50 AM
THABADGUY
Brakes
08-11-2015 04:43 AM
Quick Reply: Will 4th gen sun visers work in a 3rd gen?
