T-Top A Pillar Molding Question
Old 10-13-2003 | 09:32 PM
kerryismygirl89's Avatar
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
For all those that have t-tops... you know the A-Pillar molding that runs down the edge of the front window? There is a rubber piece sort of on the outside of it, that's like a real flimsy weatherstripping piece. Mine are all cracked, brittle and are falling apart. Can this be replaced? Does this even do anything? I'm having some leaks and I wonder if this has something to do with it.
Thanks.
Old 10-13-2003 | 10:36 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I'm going to assume that 'weatherstrip' piece was an intergral part of the trim piece (similar to how the inner windlace is sold as part of the door panel cap).
The LH p/n is 20229748 (pontiac) and was not available using www.parts.com so I would assume the OEM stock has been exhausted.
I can't imagine it being useful for anything other than hiding the metal behind the trim piece (beautification, hide the gap left from a piece that isn't an exact fit) and maybe a little rattle noise control.
Old 10-13-2003 | 10:41 PM
deadbird's Avatar
Engine: TPI 305/ v6
And before I forget, I'm guessing this is the part in question ?...
Old 10-13-2003 | 11:21 PM
demonchild's Avatar
i tried to save mine with a lot of armorall(sp?) and a lot of silicone. then i epoxied it back to the pillar. worked pretty good.
Old 10-14-2003 | 07:44 PM
Car: 1989 Firebird
Yes, that is the piece, deadbird.
Old 10-17-2003 | 12:10 AM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I have the same problem on mine.. I took mine off and just picked up some tall foam weather stripping ant put that in place.. looks good.. I kept the originals though... I had ckecked with the dealer.. and the only way I might have a chance of getting it is if that whole panel was available new.
Frozer!!!
01-19-2024 05:55 PM
1Aauto
Sponsored Vendors
04-09-2018 04:00 PM
1Aauto
Sponsored Vendors
08-24-2015 04:40 PM
redmaroz
08-17-2015 12:40 AM
sonu1975
08-11-2015 09:38 AM
