87-89 GTA GFX on 84 firebird
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
Will 87-89 Trans am gfx fit on a 84 firebird if i switch the nose. then will the other parts just bolt on the fenders/rocker panels????
Car: '91 Firebird
I think you need to change the shock absorber behind the nose too. 85-90's were less pointy. Everything else should bolt up, but you'll more than likely need to drill some holes.
Car: 1986 Pontiac Trans Am
Engine: LG4 305
you don't have to change the absorber.. i switched from 86 to an 85 to a 82 nose, and all fit without any modification, just bolt it righ tup to the fenders.
