Console glue?
Console glue?
Has anyone determined if there is any known glue that can be used to repair the console and console lid? I've tried epoxy, ABS/PVC cement, JB Weld, Super Glue-all to no avail. I guess I can wire-tie this thing together but that would look just a little tacky.
Car: 1989 Firebird
Engine: LB8 (2.8L V6)
Transmission: MD8 (Auto)
Oh man... you mean all of those glues won't work?
I need to fix this:
It'd be nice to fix because new ones are so expensive.
I need to fix this:
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Mine's peeling also... Might want to try JB Weld again... I used it on my arm rests then put it in a bunch of clamps with 2x4s holding it and it worked fine.
I might try JB Welding it in place with clamps holding it and see how it goes.
I need to fix this:
I need to fix this:
I need to fix this:
I need to fix this:
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I used black RTV and some black plastic spring clamps. Take the few bolts from the console cover off and it's easy to keep the clamps on in good position. Did it at the beginning of spring and haven't had any problems yet.
Car: 1989 Firebird
Thank you all very much for your tips. That 'separation' was really starting to make my interior look shabby. As soon as it stops raining, I will try to repair it.
