What year headlight motors will fit a 87 T/A
1987-92 Firebird, 1987-88 Fiero, 1988-96 Corvette. If the motor runs you may just need to replace the gel inserts inside the large gear.
instructions
Lon Salgren
Top-Down Solutions
instructions
Lon Salgren
Top-Down Solutions
Car: 94 Firebird
Engine: 3.4L
Transmission: t5
ok so I have a 85 and laid My hands on a pair of 88 motors... what's the big diff? The 88's are smaller and make much less noise than My 85's when they pop up... can I easily swap them?
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Pete
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
'82-'86 used a 3 wire headlight connection and dual gear drive. 87+ use a 2 wire connection and single gear drive.
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I believe you can use the 4th gen motors also. They use a differnt connector and that's it(I think). You might want to look at them though. I think that's what I used on my fiero when the headlight motor went out on it.
Check it out, you might be able to get a brand new one for half the cost instead of getting it from the dealer.
Ghettobird52
07-05-2024 11:18 PM
1992 Trans Am
05-10-2023 07:19 PM
Zachattack0925
08-12-2015 09:52 PM
