Berlinetta auto shifter removal?
Car: 89 T/A
Engine: 305 TBI (Hopefully LS1 someday)
Transmission: 700 R4 (T-56 is planned too)
I've removed a thousand F-body shifters. They all have the little staple - like - clip in the front. Not the Berlinetta I was in at the junk yard yesterday. I wanted to take the shifter plate to put in my car, but can't get the shifter off. I couldn't find any way to remove it. Anyone ever done it? It had a cool looking radio, anyone need parts from it? I'll be back in it this week, I hope it's still there.
Thanks,
Wayne
Thanks,
Wayne
Car: 1992 Camaro Z28
Engine: 350 L98
I havent removed it from a Berlinetta but I have removed one from my 86 Z. They should be the same styles. To take the **** off first you have to pull up on the button. Then you should see a little C-clip. You need to remove that then the **** will just slide up. Getting the C-clip off is a little tricky. I think they make a tool for removing them but you can also use something with a sharp point and a screwdriver.
Engine: 350 L98
No, sorry for not making my self clear. First you have to pull the button completely off. Then when you look into the shift **** you should see a c-clip. Remove that and the **** will slide up.
NBrehm
08-25-2015 11:49 PM
