Replacing a door...how to?
Car: 87' Iroc
How hard is it to swap a door and swap the interiors? Does the hinge just unbolt or will it be destroyed in the process requiring new mounts? Does the interior and power wiring switch easily? Any special tools needed to do it?
1 Post
Car: Z28
Take the door panel off and disconenct the connections from the power window, power door lock, lock switch and power mirror and mirror switch if equiped. Then squeze and pull the boot where the wires go through on the outside of the door and pull the wires out. Then you could easily remove the door simply by removing 6 hinge bolts. One of them is behind the kickpanel. Removal of the fender might be necissary, you can do it without remving the fender but it's not too hard to do so i always take it off to make removing the door easier.
Car: 87' Iroc
Thanks, my door has a pretty nasty dent courtesy of me, it' s an eyesore, doesn't sound like it's that hard to do, I'll give it a shot.
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
wait if u take off that plastic kick panel where the hood release handle is you can access the lower door hinge bolts from inside the car?? i was looking at how to remove my door, the top bolts are cake but i cant even see the bottom ones clearly and cant get a socket/wrench on them at all. i gotta go check this out later, if u can get the bolts from inside that would be sweet.
Engine: 3.1L v6
if u take the center one out will that hinge come out or no? you still need to take those other 2 out on the lower hinge? so in total, the lower hinge has 3 bolts, the top has 2?
1 Post
Car: Z28
Both hinges have three bolts, all three bolts on each hinge must be removed in order to remove the door.
The drivers and passangers side isn't all that different. It's just the antenna mount will be in the way when you try and get to the bolts. Another reason why I suggest taking the fender off.
