Where did this come from?
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
I took out the carpet so I could dye it and then I started sanding the interior so I could spray some primer down and get some new insulation in.
I discovered rust under the driver side rear passenger seat, I am not too concerned about it, I got POR 15 and such.
BUT. I dont want it to rust anymore, so where do you suppose the water that did this damage came from?
Furthermore... This bolt is rusted.... but what does it connect to? Can I just take it out and replace it, or does it hook to the rear suspsension somewhere?
![](http://www.angelfire.com/ex/mrfrumpypants/RearSeatRust.jpg)
![](http://www.angelfire.com/ex/mrfrumpypants/RearSeatRust2.jpg)
![](http://www.angelfire.com/ex/mrfrumpypants/RustedBolt.jpg)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Re: Where did this come from?
Car: 1991 Z28
Transmission: 4L60 automatic
The caulking around the hatch hinge bolts,where the hinge bolts to the roof, may be bad and causing the leak.Also besides the caulking there are gaskets there too.Another possibility is the weather stripping is coming loose in that area too.
