ground fx!!
Old 07-20-2003 | 12:37 AM
84camaro350's Avatar
ground fx!!
hello, i own an 84 base model camaro and i want to put ground fx off of any thirdgen with the ground fx pref. off of a 91 or 92, if anyone can help tell me how to install them, and pictures of the connectors and such id really appreciate it!!!!
Old 07-20-2003 | 08:53 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
First you'll need the 91-92 Front Ground Effects, Side pieces, door pieces, Rocker pieces and rear section.
You'll need a 91-92 Nose, 91-92 Bumper Cover, You'll need to weld the metal mounting strip under your door for the side ground effects. And you'll have to cut some holes in your fender...Its alot of work. My car was already a Z28 and converting to 89 Ground Effects was alot of work!
Falcon50
08-22-2020 04:26 PM
$750 L98
11-07-2015 03:26 PM
Thaney9
10-15-2015 07:37 AM
lewandom
10-01-2015 09:15 AM
Quick Reply: ground fx!!
