high rise spolier convert
Car: 1990 rs, pride and joy
Engine: 305 tbi
Transmission: t-5
Right now i have the regular spolier not the high rise z28 one. Now is this going to be hard to convert, going from the low one to the z28 high rise? 90 rs if that helps
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Originally posted by D M N
its besicly just a bolt on
The 3 piece, when removed, needs to have the holes filled in the decklid and the ¼ panels as well. There's a few ways to do it but, welding is the better of them. The highrise bolts to the outer edges of the decklid and on the center post (of the wing to the decklid). New holes will have to be drilled and old filled. This is not a simple bolt on and call it a day install (unless you go for the dual spoiler look... )
Even if you had the (I [think it was 88 only) low rise, the 91-2 high rise still doesn't share the same holes exactly.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Originally posted by confucius101
i was/am thinking about putting one of those on my 91 bird
![](http://www.transamws6.com/pics/transam/drv_side.jpg)
![](http://www.transamws6.com/pics/transam/rear.jpg)
Car: Camaro
Its bolted on , gut the trunk area remove the taillights and the plugs in the deck and its off. Filling the holes will almost double the price a body shop will charge to do the job unless you know em good.
Engine: TPI 305/ v6
Originally posted by Spdfrk1990
you have to take out the interior trim panels on the inside
Hotrodboba400
12-10-2019 07:07 PM
