mechanical 145mph speedo part number
Car: 89 S10 Blazer
Engine: 4.3
from what i have read here the only mechanical 145 mph speedo is from a 85 IROC....anyone know the part number and if it is still avalible from GM?
Mechanicals were in some Camaros from late 86 until 89. Sorry, I can't provide a GM part number. Should you be searching for something used, the Hollander part number is as follows: 257-1058B. You'll probably be asked about gear ratios, but those are insignificant. Plug and play.
JamesC
JamesC
Car: 89 S10 Blazer
Engine: 4.3
cool..thanks for the help....so a 145mph speedo from any 86-89 Camaro will work?
Yes, any will work. I suggest that you simply swap in the speedo head (that way you're assured that all guages will work, providing they already do, of course). This would also be a good time to consider higher intensity 194s and/or white-faced guages. By the way, should the trip odometer be important to you, be careful because many are non-functional--extremely poor engineering on GM's part.
JamesC
JamesC
1992 Trans Am
05-10-2023 07:19 PM
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
IrocZ'85
08-17-2015 06:24 PM
