Mirror, Self-Dimming, Compass, Temperature
Transmission: auto
I was able to grab one from a Buick Roadmaster wagone--but it only has the digital compass in it. I think it has 4 wires in it. Is that the same setup you have--4 wires?
Transmission: auto
it's been over a year since I installed it--but I think 1 is ground, 1 constant hot(for compass), 1 key hot and I think the other is hooked to the dome light--for them(map lights) to come on when the door is open.
1 Post
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
I have a Gentex with compass and auto dim.
its 3 wires:
ground
aux power
reverse (+12)
the 12 in reverse turns off the dim while youre backing up.
there will be more for temp sensors but sorry i dont know em.
its 3 wires:
ground
aux power
reverse (+12)
I am also interested in getting a compassed rearview mirror but i don't know how much they run. does any1 know?
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
I was going to snag one off of a Roadmaster but changed my mind after I followed the fourth wire. I figured out the ground, power leads, but another wire followed the center door pillar, down under the carpet into a tee type set up. I figured it went to sensors or something like that.
Didn't want to spend the time to follow through on it though.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
the green wire more than likely goes to your backup lights, when your in reverse the self dimmer does not work. I have been using ones from Rivieras for years now. Mine were only 3 wires
Black - ground
Green - reverse lights
red - switched power. ( I think it was red )
As a note: the units for the self dimming portion is all self contained. The compass that I have for my overhead console is self contained. an outside temp (OAT) sensor has a senser under the hood usually just behind the grill...
If you look at the mirror, there is a sensor on the front and one in the rear (mirror side) to tell it when to dim and not...
John
Black - ground
John
1 Post
Car: 86 TA
i ran all the wires under the headliner, under the pillar next to the windshield, then down under the passenger panel. i used the same aux and power as my stereo uses, since they were the easiest to get to.
Pac J
05-17-2020 10:44 AM
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
