Celing Padding
Celing Padding
I need help, the celling padding above the passenger seat is comming off. I was wondering if there is a way to fix it or do i need to put in all new padding? thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
Are you saying the headliner is sagging? The best fix without jamming thumb tacks in there permanantly (:nono: ) I have found aside from replacing it is pull the part that is coming off back, clean both the backing and fabic off good, spray some 3M Super 77 adhesive on the backing and lightly on the headliner fabric, let it tack up a little then push it all back together. Use a couple :cringe: thumb tacks to hold it for about 24 hours. Then it should stay up there.
If the whole thing is needed to be replaced, you basiclly follow the same steps to apply new headliner material.
Vintageracer
09-24-2017 12:34 PM
the_hamturdler
09-22-2015 02:59 AM
