removeing steering wheel
Old 07-02-2003 | 04:59 PM
USMC RCT's Avatar
Car: Trans Am
Hey everyone my buddy just gave me a free grant steering wheel off his camaro but i dont have a steering wheel puller to take my stock one off, is there any way to do it withou buying a puller? thanks joe
Old 07-02-2003 | 05:36 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
well you can unbolt it and pull like a crazy ... ive gotten one off that way .. also busted my nose .. Could probabaly try a hammer on the back but a steering wheel puller would definately help a lot. They're cheap
Old 07-02-2003 | 06:05 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
Just go to auto zone and "rent it" they have it where you buy it then you keep it as long as you buy it and then return it with out a hassle. that is how I did mine. I tried to rip it off but it would not budge, and I busted the column loose
Brian
Old 07-02-2003 | 06:07 PM
USMC RCT's Avatar
Car: Trans Am
ok thats not funny but i had to laugh :sillylol: so there not that much? i guess ill just buy one to save my nose,
thanks
Old 07-02-2003 | 06:22 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
10-15 bucks
Old 07-02-2003 | 08:20 PM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
Here is a method that I have used successfully several times, but you have to be careful or you can damage the threads on the shaft. It works better with someone helping you, but can be done by yourself.
1. Remove horn button and loosen nut to the end of the shaft, but do not take it off. The top of the nut needs to be even with the top of the shaft. This will help protect the threads, and also keep you from busting your nose when it comes off.
2. You will need a piece of wood to set over the end of the steering shaft.
3. Sit in the drivers seat and grip the left and right side of the wheel and pull up with a even, steady pressure.
4. While you are pulling on the wheel, have a buddy lay the wood block on top of the shaft and give it a sharp, but not heavy, blow with a hammer. Be sure to hit it dead center, or you risk damage to the threads.
Most (but not all) wheels are not that tight, but if ater 2 or 3 hits and it is not moving, it's probably best to get a puller. And like Skatepunk60 said, sometimes you can even just pull them off. Only ever had that much luck once.
This has worked for me several times when I have not had a puller available, but your mileage may vary. And no, I have never damaged the threads or shaft by doing this.
Old 07-03-2003 | 04:40 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
I bought a puller for $5 at a local auto parts store. Worked just fine and my wheel was stuck on there like crazy. The Autozone idea works also I did that to remove my o2 sensor. You just buy the tool and bring it back they return your money, if you got one local thats a good way to go.
Old 07-03-2003 | 04:42 PM
omcrider's Avatar
Car: 1988 GTA
Engine: 5.7L/L98
Oh by the way, you are aware that you will need an adaptor kit for that Grant wheel right? About $20.
Old 07-04-2003 | 12:31 AM
USMC RCT's Avatar
Car: Trans Am
well im and idiot and forgot about that till i had the wheel off so ill have to go back tommorw
Frozer!!!
01-19-2024 05:55 PM
backtothe80s
09-05-2015 01:39 AM
Keiffer76
Car Audio
08-10-2015 12:37 AM
mustangman65_79
08-09-2015 04:00 AM
johanlindgren
Wheels and Tires
08-06-2015 04:32 PM
