My wipers are going granny slow.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
I turn the on and they are the slowest thing ive ever seen, and the handle you turn to make then speed up/down can spin 360 degrees...not good? When i hit the button thing to make them spray they dont even think about spraying, any ideas? Are the motors hard to replace if i need to?
Re: My wipers are going granny slow.
Car: 84 Z28
Engine: 355c.i.
any idea where to start with the switch? im much better with motor stuff than electrical stuff hehe.
from what you've described, it sounds like you need a new switch...if you can spin the speed selector 360 degrees, then you probably have to replace it. As far as the washer button not working, get a voltage meter and see if it is even functioning.
from your description, the switch sounds to be trash.
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
dont mean to steal your thread, but, mine on my car are going slow when they are in the first 6 inches of the window and the last 6, and they wont park correctly either unless i use them for 30+ milnutes then they work perfect. i think the motor might be going...what do yall think?
Car: 84 Z28
Engine: 355c.i.
well i don t have a clue, how hard are the motors to replace? and the switch inside the car?
The motor is a piece of cake. It pretty much just drops right out. I've been trying to figure out the switch thing for a while now. It would be east with the steering column out and broken down but I'm lost as to how to do it while in the car.
Car: 1984 F41 T-Top
Transmission: 5 speed
Check out this site ... I have seen diagrams there.
http://www.cybrrpartspro.com/Manual%...delLookup.html
Check inside the wiper houseing ... you may just have to change the grease out.
If not then look for one at a junk yard.
1Aauto
Sponsored Vendors
09-23-2015 01:09 PM
1Aauto
Sponsored Vendors
09-23-2015 01:00 PM
