Manual Mirror to Power Mirror swap
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Firebird V6
Engine: 2.8
Transmission: auto
Hi,
Is there anybody have did Manual mirror to Power mirror swap before??
My firebird is manual mirror, I need to adjust it everytime when I park (to look at the ground), its got poor function, is that easy to do a Power mirror swap??
Joe
Joe
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Well, if you aren't intimidated by running a lot of wires, then it's not too hard. I think there are 5 wires that go from each mirror to the center console on a firebird, I think the camaros have the control on the door.
I'll be doing the conversion on my 88 Formula sometime this year, not really a priority at the moment, but I will do it eventually.
There may be a relay or two, but I am not sure since I haven't looked at it in depth.
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
I will be doing it shortly, I got the original wiring too, just need to run it through the dash. Doesn't look to hard, looked a lot more intimidating when i had to get the wiring out of the harness for it but looks pretty straight forward.
I have the wires run for mine and just need to install the mirrors. Just take your time and it's no biggie. Just takes a bit of time to do right. I'm a bit worried I'll screw up the cut uot for the switch too.
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
1992 Trans Am
05-10-2023 07:19 PM
