Should I get a GM or aftermarket fender?
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I have a 92 RS and it needs a new front passenger fender. I've heard some nightmares about aftermarket crap lining up though. But I also have nightmares on how I am going to pay for the GM stuff!!!!
Is it really worth it to get the over priced GM Stuff??
Has anybody acutally use an aftermarket front fender? If so could you tell me what brand it was please.
Check Hawks and Thirdgenresource for used fenders. They are pretty cheap and are usually in great condition. I got mine the other day and all I have to do to prep them is scuff them up for the new paint.
Much much cheaper then new GM and still cheaper then aftermarket.
Car: See pic above
Engine: Too Small
Transmission: Broken
Do used! I asked at the dealer $454 for a new pass. side fender! I still got kind of screwed at $150 for a used one, but when I checked with a few specialized dismantlers, they told me it would have to be shipped freight, and it would cost twice what the fender did to have it sent to me.
Car: 92 Camaro
How much for the shipping?
I've decided to go the used route but whenever I find one they **** me over with the shipping. Always >100 for a $75 fender!!!!!!!!!!
Is this what you guys are getting?? The thing isnt that heavy afterall. I had 2 iron heads shipped for $50 - much heavier than this I'm sure.
Car: Take
Engine: Your
Transmission: Pick
Definatly get a used one. Aftermarket body parts suck. They are thinner, and sometimes not dimmensionally correct. GM fenders are great, but like you, its alot of money for a piece of sheetmetal. Used ones can be a gamble, because you don't always know if the junkyard car had a fender replaced before. I got a used fender and it still had the VIN number on the inside, so I knew it was an OEM panel.
And its not so much as being heavy, but its OVERSIZED, so it had to be shipped freight.
Car: See pic above
Engine: Too Small
I tried an aftermarket passenger side fender on my Formula when it was being repaired. The only problem I noticed was the point where the front edge of meets the bumper cover. The seam is tight. This could possibly be from the hit or the panel since the alignment for the drivers side is just slightly off by a hair as well.
Otherwise the body lines and everything else turned out good. Don't get me wrong,I'd much rather have a real GM unit but for now it'll do the job.
I also recommend buying a used GM fender. I bought a repro RF fender (made by "Cobra King") and couldn't get it to line up perfectly. If the center body line was straight, the rocker body line was off 1/4" and vice versa. Also: the repro fender didn't have the antenna hole. I planned on shaving it anyway, but if you are putting the stock antenna back on, you're going to have to drill.
A good tip when buying used body parts is to bring a refrigerator magnet with you and run it over the panel to check for bondo. If the magnet doesn't stick, there's body filler in the panel. Obviously, you don't have that option if you buy over the internet though.
Car: 1992 Camaro RS
Axle/Gears: 10bolt, 2.73
If a bodyshop is doing all the work on one's car, would they be able to someone make an aftermarket fender sit correctly?
Shipping from the U.S. (for a rust free fender) to Canada is going to be crazy, so I'm okay with biting the bullet and going aftermarket.
Car: 92 Camaro
Car: 1992 Camaro RS
Whenever I buy something from the states, I pay 14% tax based upon the insured value. I bought blisters for 110 USD, but they were insured for 200 USD. Ouch.
There's often a handling fee (somewhere between 5 and 15 CDN) and sometimes brokerage (I've paid up to around 60 CDN). If customs doesn't think the part was made in the U.S. for any reason, then I also pay duty (which is a real pissoff after all the other fees). I can get a refund on duty if I prove it is actually a product of the U.S., but the last time I filed for a refund, it took over 6 weeks to be processed.
There's a warehouse in my city that stocks Cobra King aftermarket body panels. A fender's 100 cdn, a quarter's 175 (I think). I'd rather pay them and walk away with my part, than buy a used one for the same amount and pay at least the same amount again to get it.
Car: 92 Camaro
Car: 1992 Camaro RS
And all of that's on top of whatever the freight company charges for a cross border run.
So, if an aftermarket panel doesn't sit correctly do you have to just buy another one, or can a bodyshop still work with it?
Car: See pic above
Engine: Too Small
They can try and work with it, but ultimately, if it doesn't fit it doesn't fit. The tolerances on aftermarket panels are a lot greater than on OEM, so you may find that the first few don't fit and the third or fourth one does.
I know when I was in an accident, I asked the guy at the repair shop about the aftermarket parts, because farmers insurance only wanted to pay for that, and not an OEM one ( ). He told me that they'll order the aftermarket part cause of the insurance, but if it doesn't fit, they'll send it back and order and OEM one and tell the insurance company too bad.
How much damage is there to the fender? You may do better to have the shop try and repair it as opposed to using an aftermarket one. Them spending an hour to pull dents costs the same as them spending an hour trying to get an aftermarket fender to line up right.
Car: 1990 RS
Transmission: TH-350
i just etch-primed my aftermarket fender today, then i primed it and bolted it up to see how it was gonna fit.....PERFECT...got it shipped to my door for like 74 bux. i cant even remember the name of the place i got it, but the fender was a Parts Of America fender. painting tommorow after i get it edged in. also fixing a dent in my door. so not only do i get to blend the door in, i get to buff buff buff. lots of fun
Car: 1989 C4
Axle/Gears: 307
Back when I had my Camaro I replaced the DS fender, no I dident smack it. Cost me $45 from Certifit, $12 S&H. Fit no problem took paint very well and was almost as thick as the original. Used parts have too many hidden supprises, sand here metal sand there bondo sand there again OH hidden rust. I'm sure Hawks sells good stuff but I wouldent pay more for a used one then a new one.
