Dash Swap
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Dash Swap
Ok I have a 86 IROc with a mint dash and 145 speedo that was in an accident in January. With the insurance money i bought a 89 IROC with a cracked dash and a 115 speedo. I know that i can swap them because they are both cable driven. Well I unbolted everything in the 86 but it does not want to come out. I know that it is the wires for the gauge cluster that I need to get out but I cant seem to get to them. I need to know how to get to them with out breaking my dash. I could use any advise or steps about the removal and instalation so it goes fast and easy.
Kevin
Kevin
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
The wires dont hold it, if you are sure you got all the screws (those around the edge and the 10 MM ones down by the lights) you still have the speedometer cable to contend with, good luck getting to it, as it is a challenge, but basically you have to push the tab towards the rear of the car and then the cluster will come out.
Engine: L98 350 TPI
Kevin
Engine: L98 350 TPI
Ok my only problem is the speedo cable. Do I just pull on it till it comes out or what?
Kevin
Kevin
Car: 93 240SX
Engine: LQ9
Kevin
Kevin
The_Phoenix
02-04-2016 07:10 AM
Pilotrick50
09-02-2015 12:48 PM
TA8487
Interior Parts Wanted
08-23-2015 01:34 PM
Vintageracer
08-11-2015 08:13 PM
