Rocker GFX removal
Rocker GFX removal
I AM TRYING to remove the rocker gfx piece on my 89' IROC.
is there a bolt you have to remove from the inside of the car to get it to detach from in front of the rear tire????
what am i missing...i cant get the the piece loose in front of the rear tire
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
If you have really really skinny arms, you can go in through the vents that are in the door jambs to get the nuts off. There are 2 of them on each side, 10mm I believe.
They are speed nuts, 11mm head I believe. They look identical to the nuts that hold the door handles on (I just changed my drivers side handle today).
An easier way is just taking out the lower rear seat, then you can go through a small hole near the very bottom of the pillar way below the speaker. Sometimes the hole is covered with a sticky black square or rectangle. I would almost swear that the nut size is 7/16.
Good Luck!
Good Luck!
Originally posted by RMK
Zepher,
Where did you get your door handle? My drivers side rattles.
Sorry to veer away from the topic.
Rob
Zepher,
Rob
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
does anyone know where to get that bracket that he is talking about removing?
New2Chevy
09-28-2015 12:35 AM
