how do i fix the nose
Car: 86 Z-28
Engine: 356 4-bolt
Transmission: Borg warner T-5
i have an 86 z-28. the nose has paint chips. origionlly black the undercoating of yellow is now showing. do i repair like metal, or are there special methods for working on plastic?
thanks
thanks
Car: '92 Rally Sport
Engine: LO3
If its just paint chips then you can work it more or less just like painting a metal body part, just remember that it flexes and take that into account when sanding. If you have actual cracks in the nose then use some 3M structural adhesive to bond it back together. Putty coat and sand over that just like you would anything else and you're ready for primer, sealer, and paint.
Car: 86 Z-28
Engine: 356 4-bolt
what grit sanding paper would u recommend for removing the paint? and what sealer do you recommend for plastic and metal.
but remember this; i dont have an air compresor and i dont have a paint gun.
