Headlight Adjustment?
Old 05-31-2003 | 12:27 AM
pat12spe's Avatar
I wanted to know if there is a way that I could possibly adjust the headlight so they look more flush with the hood and nose. When they fold down, they rest a little higher and look kinda outta whack. Is there a way I can lower them some? Thanks.
Old 05-31-2003 | 12:38 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
After removing and re-installing the headlight assemblies in my car recently for a headlight motor rebuild I have found that you indeed can make such an adjustment.
The two top bolts that hold the light assemblies need to be loosend. Then you can move the headlight around until it lines up with your hood. It takes awhile to get it right. But it will work.
Old 05-31-2003 | 12:43 AM
pat12spe's Avatar
Awesome, thanks. I knew it was something easy like that, but I didn't wanna go screwing around with it and mess something up like that. Thanks again.
J-money
01-04-2019 10:45 AM
Nervous2
10-08-2015 11:53 PM
Isaac McCormick
09-12-2015 11:20 PM
sylentnite
09-09-2015 03:55 PM
luvofjah
09-03-2015 08:08 PM
Quick Reply: Headlight Adjustment?
