Steering wheel wiggles & squeeks.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Dan, you need to figure out what part is loose. As mentioned, if it's the whole column, you can tighten the bolts that hold it to the dash. It's not likely that it's your problem though. If it wiggles from the tilt joint, you've got to take the column apart and tighten some reverse-torx bolts. There's a few threads here complete with pictures to take you through the procedure. A search should dig it up.
The other unlikely possibility is that the actual wheel itself is loose. Since those are pressed on pretty tight, it's really not likely that it's the problem. if it is that, you just remove the nut lock, tighten the nut, and reinstall the lock.
Hotrodboba400
12-10-2019 08:07 PM
1Aauto
Sponsored Vendors
09-02-2015 02:35 PM
