Speedometer repair help needed!
Old 05-29-2003 | 12:21 AM
Cuno's Avatar
Ok, I bought a 145mph speedometer from a board member and when I received it, the piece that has the spring attached to it was broken. I have an 85mph speedometer and was wondering if I could simply switch the spring and face? If so how do I get the spring off of the little shaft that it is on?
Old 05-29-2003 | 10:17 PM
Cuno's Avatar
ttt
Old 05-31-2003 | 12:20 AM
Cuno's Avatar
Well, I thought I would leave an answer to this question for any one else that ,ay need this info.
Yes you can remove the spring from the shaft and switch it to a new shaft. I used a fork to hold the spring center piece and then lightly beat the shaft out of the spring. It is then a matter of carefully beating the spring onto the other shaft.
Frozer!!!
01-19-2024 05:55 PM
IROCZ1989
01-24-2016 04:55 PM
kitt23
Exterior Parts Wanted
08-15-2015 01:37 PM
86camaroman201
Fabrication
08-11-2015 11:39 PM
GEmrsn
Interior Parts Wanted
08-08-2015 04:15 PM
Quick Reply: Speedometer repair help needed!
