can i sand my ttops down with really fine paper?
Car: 1989 IROC-Z
it appears that the tinting is on the inside of the lexan??? am i right? if so could i get some super fine grit paper to remove all the little crazings in my ttops? anybody done this? or do i just have to get new tops?
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe you will find the window clor to be solid and you will not be able to actually remove it... UNLESS someone had put an extra layer of tint on them. The set I have are SOLID!
I would be very leary of "bon-ami", I have no idea what it is, but it might not be "Plastic" freindly, the Plastic t-tops I have seen are a cast form of Acrylic, not lexan as many people want to believe. The company that made them is "Leximar" which confuses many people. You could do some major damage to the acrylic if you use the wrong chemical. It might not show up today or tomorrow, but it might in the future.
AS for the crazing, it usually occurs just below the surface and you may or may not get it all out...
Good luck
John
Good luck
John
Car: 1992 Firebird
Engine: 3.1 V6
to give everyone a little refresher on plastics:
Lexan = Polycarbonate
Plexiglas = Acrylic
Leximar = Company that made cast ACRYLIC t- tops.
hope that helps...
John
Plexiglas = Acrylic
hope that helps...
John
Originally posted by Freeze
My lexan tops after some wetsanding and polishing:
Hotrodboba400
12-10-2019 08:07 PM
gta892000
09-16-2015 01:37 AM
