? difference btween 3rd & 4th gen pwr seat track
Old 05-25-2003 | 12:49 PM
azcamaro's Avatar
Car: 1987 IROC-Z / 1992 Corvette
Engine: 305 TPI / LT1
What is the difference between 3rd & 4th gen powerseat tracks?
Does the 4th gen pwr seat track have wiring from the seat (to a wiring harness)?
How would you install in a 3rd gen????
Old 05-25-2003 | 03:06 PM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
i don't know if this helps but....
i have a 92 Z28, didn't have power seats
i got 4th gen power seats. on the end there is a little socket.
i ran a wire from my fusebox to the red wire, which is power, and a ground to the black, and they work fine
Old 05-31-2003 | 12:10 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
You really need the connector side from the wiring harness. Than I just took the cigarette lighter power, since I dont let anyone smoke in my car, and it works fine.
Old 05-31-2003 | 10:02 AM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
We have a set we just pulled out of my brother's girlfriends 85 Z28 that are power. I can check later, but it seems that the older style has a diffrent actulator setup, and is positioned diffrently ( actulator that is) than the fourth gen. I know that from far away, it looks diffrent. But I will check
Old 05-31-2003 | 10:56 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
someone mentioned that the track goes back an extra inch on a 4th gen, is this true???
If so I will get one...
John
Old 05-31-2003 | 01:47 PM
Engine: 355
Actually it goes back several inches over a stock thirdgen. I have 95 Z28 seats and it easily went back I would say right at 2". I am 6'2" and a big guy getting into most thirdgen seats is not fun, but as soon as I put the 4th gen seats in the chair went alot farther back. The thirdgen seats seems to stop over the bolts, while the 4th gen seats you have to push a great distance forward to get to the bolts to remove the seats. I really like the 4th gen seats and right now I am having them redone in red and black leather to fit the color scheme of the car.
1992rs/ss
05-19-2020 08:02 PM
Fast355
12-02-2016 07:33 PM
1992rs/ss
16
01-28-2016 10:58 PM
redmaroz
08-17-2015 12:40 AM
Eagle223usa
Brakes
08-14-2015 10:24 AM
Quick Reply: ? difference btween 3rd & 4th gen pwr seat track
