4th gen rear seats
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
4th gen rear seats
dose the 4th gen rears seats spit when they fold down like some of the 3rd gen seats do? thanks for everything!
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
done did it
i did this not to long ago, they do not split, but the bolts match up and you can use a sawzall to take care of the studs that used to go into the split seats, if you cut it well enough you wont even notice, and i might suggest replacing the star bit bolts for normal ones, they are alot less hassle.
thanks for all the help. I geuss if i want the split seats I have to stay with the 3rd gen ones.
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
