T-Top edge seal/trim???
Old 05-21-2003 | 10:51 PM
SheckyZ28's Avatar
Does anyone know where or if you can get the black seal that goes around a glass t-top? Im swapping over from lexan to glass. Or do you glass t-top owners know if it fine to use them with out. Im guessing not, because i know if you hit the edge of a tempered piece of glass it will shatter.
Old 05-21-2003 | 10:59 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
mine are glass all around exept on the lach side. t-tops are not your run of the mill glass, much stronger, less temper.
Attached Thumbnails T-Top edge seal/trim???-glassttops.jpg
Old 05-22-2003 | 01:07 AM
CrazyHawaiian's Avatar
Car: too many ...
Its considered a piece of weatherstripping. You can find them on ebay from time to time. Look for T-Top weatherstripping. I think the pieces you want are the T-Top sweeps.
Old 05-22-2003 | 12:21 PM
SheckyZ28's Avatar
This is the part im talking about.
Old 05-22-2003 | 05:44 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
I heard a good place would be Sunroof Doctor
Old 05-22-2003 | 06:42 PM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
glass t-tops didn't come with that trim.
Old 05-23-2003 | 04:55 AM
EvilCartman's Avatar
Car: '82 Z28
Mine did There was a '90 IROC-Z with t-tops in the shop yesterday that had no trim around the edges though.
Old 05-23-2003 | 07:24 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Ok, actually some of the early glass t-tops had that trim. But they also had hooks for mounting instead of the later pins.
Old 05-24-2003 | 06:48 PM
black84-6spdz28's Avatar
mine has the pins as well as the strip on the outside...the 82s had the hooks and also had that trim
Old 05-24-2003 | 08:21 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got pins on both my sets and one set has the trim and the other doesn't. Both are off of an 86 Trans Am.
Old 05-25-2003 | 10:13 PM
@ZZKKER's Avatar
come to think of it, it probably depends on what brand (or type) you have. the ones in the pic that i posted are soft ray type, i have 2 sets like that. then there are the fisher and the plexi types, all of which have different mounting types.
keep in mind that the different types off glass requier diff seals
thanks
anthony.
F-body-fan
01-12-2023 02:49 PM
Jorlain
Exterior Parts Wanted
06-30-2017 12:04 AM
Thirdgen89GTA
11-27-2015 12:04 AM
gord327
10-03-2015 02:25 PM
meeklay812
10-01-2015 04:46 PM
