POR 15 on floor pan
Car: '86 TA wrapped in '84 skin
Engine: 305 carbed
Axle/Gears: unknown
POR 15 on floor pan
i want to use por 15 to cover the floor pan of my car but was wondering if it would be ok just to do the floor inside the car or do i have to get under the car and do the bottom as well?
Car: 85 Trans Am WS6
Engine: 305HO L69
to really stop the rust, you have to get both sides. if you just do the floor side, you will stop any rust from getting through to the bottom of your carpet, but underneath the car will continue to rust away
Cold Dark Shadow- is the rust all the way thru- or a spot on the top of the pan where water pooled from leaking? If its rusting from the top down and the bottom is not rusted, coating just the top would be ok.
Diabolical- where in CT? I'm in Southington
Engine: 305HO L69
I live in New Milford, but I work in Southbury. Not to far from Southington. My friend's exgirlfriend used to live in Southington.
Engine: 305 carbed
Axle/Gears: unknown
i havent noticed any rust really, i just want to take preventitive measures before i do start seein it
Por 15 really only works if its in contact w/ bare or rusty metal, according to them- its also very expensive. Best advise to prevent rust-
1) keep it clean
2) fix any body gasket leaks
3) fix any damage as soon as it happens
4) inspect suspect areas-wheel wells, behind trim or gfx
Rustoleum works good on protecting good metal.
1) keep it clean
Engine: 305 carbed
Axle/Gears: unknown
body gaskets??
body gaskets??
Engine: 305 carbed
Axle/Gears: unknown
Nope sunroof dont leak but i do need new droor seals for around the windows tho but there expensive as hell
skinny z
10-05-2015 06:23 PM
