!@#$ mad
Old 05-24-2003, 10:57 AM
  #51
cfirebird86's Avatar
Car: 86 firebird
Engine: v6
Transmission: 7004r
Originally posted by SC82TA
If you have t-tops pull the glass and unlatch the t-top and remove said t-top
Easier said then done.
New Years locked out of my car. Spare at home. Father out of town. Tried for an hour to get it that ways.
cfirebird86 is offline
Old 05-25-2003, 11:03 PM
  #52
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Also that won't work if you also lock your t-tops.... Just a thought, becuase I know I do.
Y2KFirehawk is offline
Old 05-26-2003, 12:03 AM
  #53
MasterEvilAce's Avatar
I lock'em too.. Maybe your friends would try and be stupid and unlatch it while driving... besides, if you know any ways to make your car easier stolen, wouldn't you want to fix the problem?
lock your tops.
MasterEvilAce is offline
Old 05-26-2003, 10:43 AM
  #54
mat89RS's Avatar
Ok well this may sound stupid but it worked for me.
I was stock at my job during rain and I HAD to get into my car. I wrap 3 coat hanger together so it would have strenght. pryed the passenger window and popped the electric trunk openner.
mat89RS is offline
Old 05-26-2003, 10:58 AM
  #55
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
if you take a ruler and go in from the back of the door about 3 inches, and stick the ruler down into the door from the outside, you'll feel something click. while you feel that lift the handle and the door will open heh. Works every time on F-bods.
Falconiroc is offline
Old 05-26-2003, 07:40 PM
  #56
Project_1986_TA's Avatar
Car: 1986 Trans Am WS6
Engine: Mild 350 TPI
i just used a coat hanger and made an L shape and stuck it straight down just above the key hole and push down, my door poped open as soon as i did that.
Project_1986_TA is offline
Old 05-26-2003, 11:02 PM
  #57
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
wow....all i gotta say is.......theives i think ur job just got easier if u r reading this thread
bubbakutz is offline
Old 05-27-2003, 03:54 PM
  #58
Subkid's Avatar
I've lock my only keys in the car...
Ok I know it's dumb to only have one set of keys....now that we've agreed on that. I've bought a slim jim from West Bay, how do I use it? I looked in my Haynes Manual, but there's not a good picture of the locking rod. Where on the door should a slide the slim jim in and should I pull up or push down? Thanks
Subkid is offline
Old 05-27-2003, 09:49 PM
  #59
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
i locked my keys in the car once and i called AAA to come n get me out. the guy that came had a long metal arm with a few angles on it. he just squeezed it thru the window on the side and popped the lock. less than 10 secs.
Trans_AM_88 is offline
Old 05-27-2003, 11:15 PM
  #60
88txiroc's Avatar
Consider this thread dead.
88txiroc is offline
Out-Cast
03-22-2019 09:39 PM
1992CamaroGirl
12-25-2017 08:45 PM
MM2Robinson
10-01-2017 09:16 AM
Wade787b
09-29-2015 01:15 PM
Numbah-1
Brakes
09-21-2015 05:18 AM
Quick Reply: !@#$ mad
