Fender to Nose Bolts
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
I know some of them are 10mm, but there's this plastic looking one that we can't just get out. Here's a pic.
Also, these are the only bolts that we need to take the nose out right? (plus the ones up top)
Car: 82,84,90
Engine: camaros
when i took mine off i used some pliers and just rip them out and if that doesnt work then take a screwdriver and push in the middle like this \l/ take the screwdriver and push in the middle..i cant explain it real goos so sorry if this doesnt help any
89v6fbird, unless yours is different in 89 (mines 85) that is actually a metal stud attached to the nose that fits through the hole in the fender. The thing around the stud is called a speed nut and is threaded on there. I do believe it is 11mm (same as for the door handles). Because of the size of the stud I needed to use a deep socket. Comes off nice and easy though. There should be 2 per side. I do believe the second is way way way up in the top corner (hard to get at).
hope this helps!
hope this helps!
morrow
01-13-2024 12:29 PM
UltRoadWarrior9
09-02-2015 08:24 PM
