DIY white face guages, questions.
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Since link is not working, and I have searched this board. Does anyone have the templates for 91-92 RS 110mph cluster?? If so, please post, or let me know and I will IM you my email to send them to me.
Also, whats best glue to use so that it wont bubble and jam my needles. (found from searching).
Also, what paper is best, standard, glossy, high gloss, matte, etc??
Thanks for any respsonses.
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
i think i have what you need just PM me your e mail and i'll try to send them to you
also let me know what you need i have a couple speedos, a tach, and the quad gagues
EDIT: the glossy seems to work best high gloss seems to be too much to me
Car: 91 Camaro RS
Engine: 3.1L V-6
i just thought of something... maybe some of that double sided clear tape for putting the gagues on i'm not sure if it would work or not but it seems like a good idea to me
Car: 86 camaro Z28
Engine: 305 carb
when you print those templates out and put them on your gauges can you see them at night? or is that the reason they're DIY...?
Car: 91 Camaro RS
Engine: 3.1L V-6
Okay everybody who asked me for the 91-92 gagues yours have been sent from my hotmail address slow91rs@hotmail.com so check your email if you don't get it just email or pm me and i'll try to get them to you
the gagues i sent included: 2 speedo templates, a tach template, a shift indicator template, and the quad gagues]
if anyone else is interested in them please let me know either pm me or email me
Originally posted by bubbakutz
i heard use the 3m double sided tape
1988irocz350, where did u find those at?
If anyone has the 145mph gauge set templates that are the correct size please hit me up.
Thanks....
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Check my webpage, I have some on there. But I removed the km/h and tripometer. If thats okay with you, then you're welcome to use them as you wish.
Car: 91 Camaro RS
Engine: 3.1L V-6
if they print out the wrong size you are probably using the wrong program to open and/or print them with you need to use an adobe program preferrably photoshop to open them and they will print out perfectly the same as before
Engine: 350 S-TPI
Bringing this back to life. Thanks to however sent me the templates. I finally got off my ****, and had them "personalized" for the driver of the car (not me).
Do I need to have them laminated to last longer, or not yellow. I do have some glossy paper.
Car: 1987 Pontiac Firebird
Engine: 346 LS1 V8
Transmission: T56 6 Speed
Here are the gauges I made myself. I took the gauges off and then scanned them. I then photoshopped them and printed them out on glossy paper. I then laminated it and trimmed it to fit. I also made white face HVAC and headlight switch faces. It turned out pretty well. They're pretty easy to make yourself, but if you have a template, it's even easier. By far the easiest and one of the best little mods to help the interior.
Engine: 350 S-TPI
I've got the templates, modded them to fit the driver of the car. Going to print them out this weekend. Wasn't sure if they had to be laminated. Looks like they do, so time to find a place to do that for me.
Engine: 350 S-TPI
Printing these out, have questions....
When I print them, do I do "scale to fit", or full scale?
If I do scale to fit, what do my boarders need to be??
My printer is slow, and this paper isn't cheap, I dont want to waste a bunch to get the right size.
