eBay aftermarket gauge cluster?
I'm thinking of purchasing this gauge cluster. Is this a good quality gauge cluster (only $20.00, seems kind of cheap), and will it be easy to install? I have never installed gauges before. Thanks.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2415011903
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i bought those, they aren't bad, but it is hard to take the needles off without breaking them, and harder to get them back on right, but they look good, definitely worth it.
www.classicindutries.com (or something very similar) has a replacement guage cluster for 82 to 91. I believe they use autometer guages. It is supposed to plug right in. Its $700!
dakota digital has a all digital replacement w/ a similar cost.
They look cool, but they are pricey.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Yea... that was the reason i had to buy my new 145mph Speedo....after taking the needle off 7 times and going through 3 speedos i have arrived at the best way to remove the speedo needle... however the tach oil gas and volt are up for grabs. i posted a thread on it a while ago easy for soemone to search and find out heres the link:
https://www.thirdgen.org/techbb2/sho...hreadid=159700
-Ham
Drone358
12-10-2015 08:16 PM
