nose piece removal
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
nose piece removal
i wrecked my 92 firebird and i need to get my nose piece off to put the new one on. i got every bolt i can see i just was wondering if anyone has taken this off before and knows of any hard to find bolts or anything that i might be missing
92 is the newer style nose so I don't know for sure if it changed a bit as far as mounting but I hope this helps:
-4 bolts (per side) attaching the nose to the front of the fender. One of them is way way up in the top corner. I had the light assemblies out because I was dismantling the whole car, however, you can probably reach it from underneath if you take the plastic skirting off.
-approximatey 5 bolts holding the nose to the hood latch mounting plate (in front of the rad).
-a slew of plastic clips along the bottom holding it to the bumper
I can't remember but the marker light bolts may have to come out too. Hope this helps.
Glowsock
08-26-2015 12:28 AM
