Dash Question
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
Dash Question
Has anyone ever tried to bondo or fiberglass there dash rather then replace theres? did it look good?? would you think it would look good?? thanks
Nick
Nick
They are not that expensive. If you keep a sunshade on in the window when your not in the car and you take care of it, you should never need another one. Mine is perfect and its the original dashpad.
Bondo is NEVER the solution. It is a filler designed to repair small deep dents in hard to work on areas of the car where it would never be noticed.
There is however a fiberglass dashpad somewhere that I read about. I would imaging that it would cost alot. And you really don't need to spend it if you know how to take care of the factory part.
Car: 1992 Camaro RS
well my question accually was to fiberglass the dash myself. i'm also looking into doing other parts of the car. or even gel coating. what do you think about that. the reason i'm asking is when a company replaced my windshield they craked the hell out of my dash. it had some little crack that were hard to see but since then there getting bigger.
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
i got a good condition used when from the junk yard for like $12 or something like that, not very much.
The_Phoenix
02-04-2016 07:10 AM
Vintageracer
08-11-2015 08:13 PM
