how do you remove door and bumper?
Car: 87' Iroc
i know the fender is just bolted on, is the bumper the same way? is there a certain order you have to remove things? does the door "come off" or do you have to cut the hinges to get it off? How hard it is to swap the interior out? (my door met my dads rear end)
Car: 88 GTA
the bumper has a bunch of screws that you need to find and take off. The fender is the same, a real pain in the ***. The door is really simple, 2 screws top hinge on the car, and 2 on the bottom; make sure u have a good grip on it.
Dave
Dave
Just take the bumper off first, then the fender, then the door. The door will be much easier to work with, with the fender off. BTW - Its 3 bolts per hinge, not 2.
Swapping out the interior is very easy. Just dig into it, nothing real hard about it.
Edit- Nothing to hard about the gfx either. Why wouldn't you remount them with the same hardware??
