Interior Lighting under the dash board!?
Old 05-08-2003 | 09:31 PM
Firebirdjoe's Avatar
Car: 1987 Pontiac Firebird 82k miles
Engine: 2.8 V-6 (173 c.i.)
Hey guys, There is a major lack of lighting in the interior of my Firebird. I have the map lights on the rearview mirror and the dome light.
I want to install a mini bulb for light under the driver and passanger side of my dashboard. Is this at all possible? And how would I go about doing this?
Thanks, Joe E. (Firebirdjoe)
Old 05-08-2003 | 10:34 PM
ramair350's Avatar
My 89 Formula already has lights under the dash in the footwell area, so the wiring may already be there. All you would have to do is tap into it.
Old 05-08-2003 | 10:43 PM
Dirty Rob's Avatar
Either that, or find where your dome light wiring comes into the car, tap into that, and add a separate switch for the dash lighting.
Old 05-08-2003 | 10:52 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
exactly what is the best way to tap into a wire?
Old 05-08-2003 | 11:14 PM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
On all thirdgens (pretty sure) there is a female ended plug with an orange and white wire leading to it, for a male plug to go into. It is there when you take off the drivers side underdash panel. I had it in my SC, which didnt have the lights.
Next, I had a parts car, with the lights. So I unplugged the male connector from the female, and pulled it out with the wiring for the lights, and plugged it into mine...And tada, I have underdash domelights.
You see, the female plug is already tapped into the dome light wires, so it will work automatically! No splicing required!
BRoss99
12-07-2020 07:50 PM
Vintageracer
01-10-2020 06:33 PM
The_Phoenix
02-04-2016 08:10 AM
Omega
08-10-2015 01:46 PM
Quick Reply: Interior Lighting under the dash board!?
