Door top weatherstrip replacement
Hi,
I'm trying to replace the weather stripping along the top of the door - the one that rubs against the glass when you wind it. With the window down fully, there are two screws which are still behind the glass. Has anyone got any tips how to go about this? Do I have to take the window off or what
Thanks for any help.
Car: 1986 IROC-Z
Engine: 5.0 TPI
Assuming you are talking about the piece along the top outside of the door, heres what I did. Remove the inner door panel. You will see 2 bumpers holding the glass out. loosen the bolts, roll window down and pull in. I think there are 1 or 2 bolts for the strip behind the triangle too.
1992 Trans Am
05-10-2023 07:19 PM
IROCZDAVE (88-L98)
10-06-2016 09:08 AM
