can i use this on the healineing??
Old 05-05-2003 | 11:31 AM
icebird_1981's Avatar
i am putting the cloth back on the board right and i used Elmer's Spray Adhesive. does anyone know if that stuff is any good?
Old 05-05-2003 | 11:20 PM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Nope, that doesn't work. Also, did you just reuse the old falling headliner or did you buy new stuff w/ the foam attached? Old stuff won't stick anymore.
The adhesive you want to get is 3M's Interior Adhesive (in a white can w/ red letters) NOT the Super 77! because that doesn't hold up to heat.
Old 05-05-2003 | 11:29 PM
ya i used the old one because it was clean, and i uses the whole can of that elmers stuff it hold really well, but ya i was worried about the heat issue. so this stuff i got on it now is not going to last? i just finished putting it on like 10 min ago.
Old 05-05-2003 | 11:33 PM
Dirty Rob's Avatar
Did the foam stay on the board when you pulled the old material off? If so, youre going to have to redo it. For the $12-15 new material is going to cost you, its well worth it.
Old 05-06-2003 | 03:29 PM
well u guys were right its starting to sag at the back, SOB!!! this is my second time doing this! i'm just gunna get new fabric and the proper glue and put some flames. i'm gunna make this look amazing!
Old 05-06-2003 | 03:35 PM
Dirty Rob's Avatar
When I get home this summer, I might re-do mine just for the sake of making a tech article. This comes up about once a week.
Old 05-06-2003 | 03:47 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I had my headliner done three years ago and no problem with it falling down. Also it looks factory stock, but I did have install by a Professional Upholstery Shop. I say screw the DIY sruff if you want it to look good or Half/A--ed.
Old 05-06-2003 | 03:49 PM
Dirty Rob's Avatar
Mine looks fantastic, for the low price of about $25 and maybe three hours of my time.
Old 05-06-2003 | 04:27 PM
DJP87Z28's Avatar
Well good for you. One sucess for many failures and you work cheap I see.
Old 05-06-2003 | 06:18 PM
Dirty Rob's Avatar
I did, now i dont have time to work on anything at all, so maybe a shop would be the best bet.
Old 05-06-2003 | 10:33 PM
CaysE's Avatar
getting bored of posting this...
do a search for headliner in the body & interior forum. you will get this: https://www.thirdgen.org/techbb2/sho...ight=headliner
i think we've covered headliners pretty thoroughly at this point. elmer's spray glue will not work. 3M Fast Tack Trim Adhesive is the correct spray adhesive for headliners.
JRagus
03-19-2017 01:17 AM
NiG
07-22-2015 10:30 PM
Turbo01SS
06-21-2008 04:19 PM
Quick Reply: can i use this on the healineing??
