How much POR-15 do I need?
Old 05-03-2003 | 04:02 PM
SBlackfoot's Avatar
Car: '90 Trans Am GTA
Engine: LB9
Axle/Gears: 2.73's
Alright, enough procrasticating. I want to order enough POR-15 for my GTA. I figure a starter kit should be enough to cover the interior floorpan with one coat, but how much should I order for the undercarriage? I hope to do the floorpans/trunk and the axle at least. What do you guys think? How many quarts/gallons of the actual paint and of Marine Clean and Metal Ready should I order?
I may double the order and do my lil truck while I'm at it.
Old 05-03-2003 | 06:26 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I would start with a small quanity (2 qts) should do the under body. Just remenber that Por-15 does not store well once opened. Great stuff.
Old 05-04-2003 | 08:49 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I just did a engine bay with 1/4 - 1/2 quart. This was thined and sprayed with a gun also. and a good coat not to thin or thick.
1quart will do a engine bay and have some left over , even brushing it on. (I just sprayed it since I have all the equipment to do so) As for storing, If you put a Bag over the top then put the lid back on you wil be fine.
Old 05-04-2003 | 03:09 PM
ml258-89iroc's Avatar
Car: 1989 iroc
Axle/Gears: 2.77
I did my underside this past winter, it took me just over a qt
DuronClocker
11-17-2004 01:54 PM
Belker
04-22-2002 10:07 AM
Buck268
Aftermarket Product Review
02-13-2002 06:09 PM
red
10-15-2001 03:57 PM
TomP
08-01-2000 11:27 AM
Quick Reply: How much POR-15 do I need?
